Covering the edge of a curved step?
28 Aug 2008
Surrey
Hi
I am about to start on a new bathroom project and whilst I think I've got most of it figured out, I've hit upon a snag. I'd like to create a dual level floor by raising the back third of the floor by about 6 inches. On this I will place the toilet and wash basin. This is primarily for aesthetic reasons but will also assist with the new plumbing arrangements.
I was planning on using bamboo tongue 'n groove flooring for both levels with a thin strip of ply for the riser. I will use a bamboo veneer to cover the riser, but I can imagine the top edge where it meets the tread will be far from perfect as it will need to be cut by hand. Now if the step was straight I could presumably use a right-angled strip of metal for example to cover the join and protect it from getting chipped, but the problem I have is that this raised level will have a pronounced curve to it. How can I cover/protect the edge of the step when it curves?
I hope that I've explained this properly and that someone will have some advice.
Toby
£150 quid for 1.5meters :shock: :shock:
You can get a profile made out of metal, or some skills with a router may be needed to do yourself.
Cough splutter - I just had to go back to check the price (didn't see it 1st time).
Jesus - that's expensive.
Perhaps a little out of my price range :lol:
I'm thinking now that I could use a hardwood dowel and cut a corner out of it so that it sits on the edge of the step. I could always steam heat it and bend it into shape. What do you think?
Toby - once you've got you hardwood profile then steam-bending to get the curve is easy enough to do.
Steam chamber = length of plastic soil pipe (needs to be longer than the workpiece), a couple of end caps for the pipe (one should be a screw-on type - acts as a door to get the timber in/out), steam pipe made from a length of rubber (or plastic) tube, a steam generator (old kettle, not electric). If you want you could add a couple of wall clips to act as stablising feet.
Bending former = made from ply with a curved edge and some clamping blocks glued/screwed on.
Heat the timber in the chamber, gloves on, whip the workpiece out of the chamber and over to the former, clamp up and leave to dry.
