it hides any cracks in the corners of the room tho. I have just had my ceilings skimmed and the plasterer said it might crack around the edge. Could i just use decorators caulk and repaint this?
I'm not sure coving is dated as such - my house is a victorian terraced, 10ft high walls, it just looks wrong without coving. There isn't any in the kitchen extension though and it wouldn't look right in there anyway.
I've had to put some up on my landing and hallway. Due to budget constraints I used the paper covered poly stuff and mitred it using a knife and a little blue plastic guide (about £1.80)that I got in Wickes. The joins are all very neat and tidy (the height helps any imperfections)
