Cracked concrete lintel repair
Discussion in 'Building' started by jertum, 20 Jan 2022.
  1. jertum
    jertum
    24 Jul 2018
    35
    Thanks Received:
    5
    Country:
    We recently moved into an old Yorkshire stone terraced house. The window in the kitchen has been replaced with a wider one at some point over the last 30 years, with the opening widened and a concrete lintel installed. I recently noticed a vertical crack in the centre of the lintel, which seems to go at least half way in. There's no damage to the brickwork above and there's been no evidence of movement since we moved in, so I think it's probably been that way for a long time and wasn't picked up on the survey.
    As it's a concrete lintel - which presumably has a steel rod inside - is it likely to need attention? I've heard that it's possible to insert an addition bar (helical?) to reinforce it. Does this sound right, and if so, is it an expensive job?
  2. blup
    blup
    5 Nov 2007
    2,237
    Thanks Received:
    391
    Country:
    Get it checked out by a structural engineer.
    Blup
  3. Sponsored Links
  4. tell80
    tell80
    30 Jun 2021
    607
    Thanks Received:
    108
    Country:
    Why not post a pic on here?
  5. Dereekoo
    Dereekoo
    2 Jan 2012
    445
    Thanks Received:
    68
    Nottinghamshire
    Country:
    Has it sagged at all, how far up from the base does the crack go.
  6. Sponsored Links
Loading...
Share This Page
