Cracked Window - Need new unit
2 Feb 2016
Hi folks,
Just noticed a long crack in one of the bedroom windows. The crack is on on the internal side only, so I guess it's a case of thermal shock (windows are around 20yrs old). It is internally beaded so my plan is to pop the unit out, measure it and then source a new one. I have a couple of questions:
  • When taking the beading off, is there a particular order this is normally done in? e.g. Top, then bottom then sides? (Windows are Profile22, if that helps).
  • Where is best to source a new unit? Can I just rock up to a business unit on an industrial estate and get one there? Is there anything I should particularly look out for?
Many thanks!
-NS
I went for 'middle of longest sides' first, with my thinking being that this has least amount of force keeping it in place.
I used yellow pages and google search and made sure they made them locally (look up glass and mirror cut to size suppliers).
SFK
If the corners are mitred then start in the middle of the longest bead and lever in towards the centre, once to have enough peeled away you can get your fingers behind and peel the bead off into the corners
If the corners are scribed in where one bead overlaps the other i.e. the top and bottom beads go first and the sides overlap then you can start at the ends of the side beads
