I have recently noticed some exterior render cracks that may be causing damp on an interior wall. The cavity has been filled with injected insulation and I cannot be really sure if the insulation is acting as a bridge within the cavity to carry water to the interior wall. I have bought some filler that claims to resist cracking and shrinkage but it needs to be applied to a dry surface. As we are now well into quite a wet October it is very unlikely that the surface will be dry enough to apply the filler. I have filled one of the cracks before with a sand and cement mix but it always cracks again thus the reason for wanting to use a filler that is flexible. Any suggestions?
