Cracks in plaster and flaking paint
18 Jul 2023
Hi all,
I am currently in the middle of stripping off pine cladding in the utility room because it looks really outdated and I have come across a few issues with the existing plaster underneath. First off, there are quite a lot of cracks in the wall as it looks like it has been cement rendered, followed by a finishing layer of skim. The second issue is that whoever painted this wall originally, didn’t mist coat it by the looks of it as I have already scraped off quite a lot of paint as I plan to put up some shelving eventually and need a reasonable fixing.
The problem I've got is that I don't want to start hacking off all the plaster for the sake of it, as I think by putting some bonding in the cracks and then covering over with some jointing tape will do the job? All I can say is that these don't appear to be cracks in the brickwork as that appears to be all fine, my theory anyways is that there has been a bit of movement over the years followed by some areas which have lost a bit of bond to the brickwork underneath.
Would I be better off to strip all the paint off the walls first, then fill the cracks with bonding and put some scrim tape over the filled areas, followed by reskimming? As I really want to keep the costs and agrow down to a minimum if at all possible. Any suggestions will be greatly appreciated!
you could just put pasterboard over the top and tape and skim. You will lost about 15mm from the room.
