cross over bend between too points
28 Oct 2014
Leeds
Hey I can pull a bend as in the picture but how do I make it so its a set distance been the two ends of the pipe? That will be going in to elbows?
Thanks. Its not totally like that though I just need 2 45 degree bends pulling on a piece of pipe but need the end of these 45 degree bends to be 400mm apart. Any help?
Are any of the other measurements critical? Because otherwise if you allow 100mm for the straight section jn the middle and pull your 2 bends, then at some point they'll be 400mm apart. Just measure and cut.
or, go to a proper plumbers merchants, and buy 2 x 45° solder bends (end feed, or integral solder ring). then you can cut the section between them to the millimetre as required.
Yes I am aware that this costs time to find and purchase, risks a leak if not soldered correctly and will cause greater frictional losses than a pulled bend, but if it works OK?
Part number 38267 at screwfix
If you want to avoid the soldered corners just bend two separate 45s and cut to the mm and solder them on the straight bit! Less neat though. So many options depending on your requirements!
