Crossbatten - confused?
24 Feb 2015
West Glamorgan
Hi, just after a bit of advise.
I want to lay a small board area in my loft, and I read some previous threads which mention cross-battening the existing roof rafters, I think this is the way forward.
Just one question?
I have 8ft 2x4 planks and I need to raise the floor for insulation to fit underneath.
Do I just lay these on top of the rafters and screw them into the rafters (top down) or do I cut them to shape and lay then in between the rafters and screw from the side? Lastly, do I cut them to shape and then screw then into the rafters top down?
Any thing I need to be aware of before I start? Do's and dont's?
Some sort of picture would be appreciated.
On another note: There is a video on YouTube which suggests this idea...Im not a fan of this as it involves drilling directly into the roof trusses, which is probably a very bad idea. Any thoughts?
https://www.youtube.com/watch?v=QkiA_B7vTTE
Thanks.
Richard.
Lay the insulation between the trusses - between the bottom chords/ceiling joists.
Then simply screw your 2" x 4" bearers to the top edge of the chords - dont worry about squashing down the insulation under your platform.
You can drill pilot holes if it makes it easier to screw down.
