Crunching Potty Puma 80e
20 Oct 2008
Leicestershire
Hi there,
I have a problem with my Potterton Puma 80e combi boiler. It would seem that whenever I run the hot water through the taps, hot water is produced and fine, great. However when I close the tap the boiler makes a loud crunching and clicking sound (like a brick in a washing machine!) and if I dare leave it turned on eventually the "lockout" light comes on. The boiler then continues to run and for some reason the radiators get hot as if I`ve turned on the CH?
There is a pressure valve under the boiler with 2 needles a red on on about 1.5 and a back on just past 0. Neither of which seem to move at any point.
I`ve tried bleeding the radiators upstairs as I can hear water gurgling through them, but when I open them valve I can hear air escaping for a minute or 2 then nothing, no water dripping out, no air coming out?
I`m sure its something really simple or rather I hope so, things are a bit tight at home and I really can`t afford a costly repair bill!
Thanks in advance!
Its the DHW demand switch sticking on after a demand.
Search for more information on this site.
There are several possible causes!
could also be a dead leg filling up with air on the hw circuit or if you have an intelligent washing machine sometimes the hot is not used & fills up with air
could also be a dead leg filling up with air on the hw circuit causing the boiler to stay on for hw momentarily, or if you have an intelligent washing machine sometimes the hot is not used & fills up with air
