Curing Condensation in an Internal Stair
9 Nov 2009
Edinburgh
Two single storey flats, one on top of the other. Entrance doors are on the gable end. Way into the ground floor is a door on the right. Way into top flat is a door on the left, turn hard right, and climb the stairs that in effect run up the inside of the gable wall, turn hard left and you're in. There's no internal door separating the main flat from the stairs.
Now, both flats nice and toasty warm, but that stairwell is unheated and prone to condensation on the gable wall.
What's the best way to reduce the condensation? Rad at the bottom of the stairs to heat the air and reduce condensation? Fitting a door at the top of the stairs to reduce air movement might be an option, but doing so would dramatically reduce the amount of natural light.
Anyone solved a similar situation?
Only way really to cure condensation is removing the point of ingress of moisture. A rad won't remove the condensation, when the warm air cools that's when the moisture would then condense. Usually a window.
Only other way to deal with it is to add ventilation - trickle vents or passyfier vents top and bottom to provide airflow.
I'm guessing the source of the moisture is probably the flat. I don't think there's much of a noticeable flow of air up the stairs. Perhaps the easiest solution would be a door at the top of the stairs.
You need to get ventilation in somewhere. Fresh air in and somewhere for it to escape.
Air bricks, trickle vents etc.
