Curtain track external pulley
23 Feb 2005
Surrey
I'm fitting a swish corded track into a bay. The plastic type with the roller gliders.
http://www.dunelm.com/webapp/wcs/stores/servlet/en/dunelm/product/superluxe-corded-track-1000026096
The previous non-corded track, curved round in the bay, and then came out round an external corner so that the track was flush with the wall that the bay itself was set into. If that makes sense!
This meant that when curtains are open they sit against the wall and not in the bay, so more light is let in (and it looks much neater)
The internal corners are gentle enough for smooth operation, but the external one means that the cord would come out of the back of the track and try and cut into the corner of the wall.
Does anyone know of a retainer to keep the cord within the track, ideally with a moving part to reduce friction, or a very small pulley than could be fitted to the corner so the the cord runs over it.
Essentially like a tiny version of the Hozelock corner rollers that fit to an external corner.
https://www.wigleydiy.co.uk/hzk-hos...n1seMLHJczQieOrjj-J7MF2xueM6RP2xoCTyUQAvD_BwE
The curve should not be accute enough to cause any problems , hair dryer can be used to soften track to allow correct fitting.
This is an external curve.
I don't think it's gonna go as the gliders run in the same channel as the cord, so the cord being pulled out will foul the rollers on the gliders.
I might have to add a small curved extension track on the other side of the cord pulley unit and extend the end of the curtain round the corner, but the curtain won't clear the windows as I'd hoped.
Last resort I'll bin the cord and pulley and leave it as manual operation.
