Hi to all,
My first post on here....section=2&category=12&resultPage=0--331009436
3 or 4 Kohler watertile bodysprays http://www.ca.kohler.com/onlinecata...section=2&category=8&resultPage=0--1561665133
1 regular Showerhead
I will use 3 volume control valves for those items and will be all tied up to a thermostatic valve
#2 I'm worried that a 1/2 pipe won't be enough for this type of system and that the pressure won't be enough... i know for the bodysparays i'm supposed to do a pressure balancing loop. any suggestions??? comments ?
i'm pretty close to the water heater if that makes a difference.
#3 since i have no previous experience in this... could all these devices should be run on 1 water line or on multiples ?
#4 what about the shower drain.. all plumbing surounding this area is 1 1/2.. is having a 2" drain that neccessary ?
#5 i thought of running PEX instead of copper... would this be a good idea ? or should i just stay with copper ?
#6 the thermostatic valvel that i looked at are kohler too.. they come or in 1/2" or 3/4". could i use a 3/4 valve with fittings on the water feed? would that help the output ?
If you want you can look at the specs of the kohler devices i mentionned maybe that will help you in knowing what is needed
I really thank you all for you help
Alex
[/url]
Alex
[/url]
