croydoncorgi said:You can get a 'flexible file' (actually a steel wire with teeth on it and rings at the ends) which can be used when clearance is virtually non-existent.
Be careful you have a good plan for what happens AFTER the cut!!![]()
http://cgi.ebay.co.uk/NATO-COMMANDO...ryZ36077QQssPageNameZWDVWQQrdZ1QQcmdZViewItemDan_Robinson said:croydoncorgi said:You can get a 'flexible file' (actually a steel wire with teeth on it and rings at the ends) which can be used when clearance is virtually non-existent.
Do you know where to get one (or two)?
Softus said:or do you have buy the top-o-the-range Santa Claus Variety pack, or what?![]()
diy_darren said:What tools are best for cutting copper pipes in tight spaces? I have a small hacksaw and something similar to this, what would you recommend?
s#item number 150151203239Softus said:That URL doesn't work for me - do you have an item number?
