- Joined
- 25 Jul 2022
- Messages
- 9,681
- Reaction score
- 739
- Country
It's a simple rule.Some do, some don't is the simple answer!
The ones you want out, stick and are really awkward to get out.
The ones you don't want to come out, do. Too easily
Sounds like a cheap hard plastic type, not a rubbery stretchy type.OK, so cv boot number 5 fitted just over a week ago by the garage has pulled out of it's big clip (we've been here before) and spilled it's load of grease. Again!!!
Did suggest when it went in that they fitted a softer rubber one like the one they put on other side 2 years ago which is fine. Suppose the message didn't get through, because the new one is the more rigid plastic type.
This is getting farcial now. Going in for rectification on Monday. Boot number 6 coming up!!!
Most Peugeot citroen cv boots are the hard plastic type.At this rate, it’s a dealer part needed......surely?
John
Some boots are designed to be stretched, some aren't.Either way, the PSA products last a long, long time - that’s good enough for me.
In the last incident the boot was the incorrect diameter for the CV in question, i.e too big as it came adrift.
Had it been the right size, the clip would have compressed the boot into the groove of the CV and it would have stayed on.
I avoid Firstline products like the plague - once stretched ( which I don’t approve of) they remain bigger than they should.
R & C must have the patience of a saint!
John
John
Nothing wrong with splitting the joint.Only my opinion here but I find the boot stretchers particularly brutal (although I have used them) so I now knock the CV off the driveshaft and fit the more rigid type.
John
Just don't (let them) use a cheap aftermarket rigid type
