Cycle stuck Hoover Softwave d7610
5 Feb 2006
Stuck on Cycle will not go passed 3 when selected 1 or 2 someone please help :cry:
Hi
If you advance it on to the rinse cycle, does t then carry on to the end as usuall ??
If so the heater has failed, Nice easy fix, and the parts are not too expensive.
Thanks for the reply - ah what position would the rinse cycle start from? - I can surely give it try and let you know - thanks again
it also could be your timer that has the fault on it
Sorry for bumping this one up again, it's just that I have the same model Dishwasher.
Problem is that it won't fill with water. I have made sure to empty it of water by moving the cycle on until it emptied but it just won't refill?
I have checked the external water in tube and it's not blocked. It tries to fill the machine. I know that the water out tubes are not blocked because I was able to empty it, even after filling it with a basin of water. So I'm thinking it may have something to do with a float or float switch?
Can anyone tell me how to check these things on this machine?
When I set the dishwasher and push the power button you can hear it trying to load the water but it's just not happening.
ANy suggestions appreciated. Thanks
