I have a BG branded Worcester 430/i boiler, fitted about 13 or so years ago. Lately I have been having a lot of trouble with flame failure errors.
It is just set to Water Heating at the moment, and I have observed that it always seems to be failing when the tank is actually pretty hot, so I came up with the idea that the problem would be the tank thermostat (and then the hot water demand not turning off, and everything getting too hot)
However, when I took the tank thermostat off, I found that the wire to the thermostat had been cut off. To the end of the cable from the boiler was wired what I believe to be a thermistor. A bit like this - https://buyplumbingonline.co.uk/firebird-boiler-tank-thermistor-cable-combi-pcb-acc000wtp.html - but with the end being plastic coated. Also, it seems to be just twisted and taped, rather than connected any other way.
For the moment, I have just wedged the thermistor behind the old thermostat, as I guess it needs to be in pretty close contact with the cylinder, but does that sound right ? No flame failures since, but I just wanted to check I wasn't making things worse somehow.
