The reason I want to know the above is because I only get hot water when the heating is on thats why I think it maybe the therm in the cylinder any help would be appreciated.
Hi looked at system in a bit more detail, found what I think is a pump, its red hot, it has "controller 's' " written on it, when it is hot water only it does not supply to the cylinder but when the heating is on it does ( the return pipe gets warm) so I guess there might be a problem with this.
it has three pipes from it and what I thought was a syhncron valve and what looks like a solenoid.
