Daikin air con unit
18 Dec 2011
Yorkshire
Hi,we have just moved and our Daikin wall mounted air con unit trips the main breaker when it switches to heat, any suggestions please
I could be a few faulty controls that's causing this problem. A good guy with a multimeter & the internal wiring details should get to the root of it.
There is a diverter valve that moves to switch the circulation from heating
to cooling.
Either the motor the valve has failed.
Thanks, do you think the valve motor is something I could change? I'm a spark but never touched ac.
Yes quite likely open the unit up and have a look.
If the valve has gone it means a vac out, brazing a new valve in
and refill of the air con system.
