- Joined
- 10 Oct 2025
- Messages
- 21
- Reaction score
- 0
- Country
Hi John,I haven't had one quite like yours, but I've had them with a strong timber frame, tile-hung or pebbledashed on the outside and L&P on the inside.
Easily improved by cleaning out and adding membrane, insulation and plasterboard, with extra sockets on the bay and mineral wool in the floor to block draughts. I like to pack mineral wool into the frame as it is easy to fill tightly with no gaps, blocking draughts, but the foam is a better insulated. You can lay an extra sheet onto the face.
But in your case I think a new timber box frame is needed, and I would use sheathing ply on the outside for extra strength and rigidity, and new brackets off the wall. IMO the old frame is poor and falling off.
If you can find a leadworker, they can probably make it more weathertight than you could do yourself.
I don't think your window contractor is up to it.
When you expose the timber, there is a chance you will find it is well made and just needs woodworm killer, new brackets and screws
But I doubt it.
Thank you for your help with this. Ideally I don't want to be touching the current framework as I believe from what I can see there is no movement and seems to be quite rigid - I don't want to disturb anything.
How would you suggest strengthening the current framework?
I think we're going to bull the celotex and for between the current framework, then put the membrane and new plasterboard. Would you suggest insulating the floor near the bay?
Thank you for your help!
