I live in an old stone cottage circa 1840 (cavity walls filled with rubble). I have no idea if there is any sort of damp proofing.
The ground floor is all one room and was tiled by the previous occupants (I wonder why? Hmm...). I have a central rug and recently discovered the bit under the sofa was damp. It's happened before but then, I thought it was because I didn't dry out the rug properly after I got flooded with surface water from the back garden years back.
I thought it might just be condensation but the underneath of the carpet is almost wet. I'm just checking whether there is damp anywhere else - so far it looks like it might just be an area about two foot square. I've never seen water on the surface of the tiles and the house doesn't smell damp. I've checked the pipe which runs from the stop cock behind the kitchen units and there is no leak.
Is this rising damp? What's the solution? I dread having to have the floor up. Not all the furniture will go upstairs! Any possibility of a 'spot fix'? Who do I get to check it? A builder? A plumber? A 'damp proof specialist'. I'm anxious to avoid rip off merchants! Thanks.
