    Dismiss Notice
Damp on internal wall and problems on external rendering
Discussion in 'Building' started by woodland81, 10 Aug 2014.
  1. woodland81
    woodland81
    10 Aug 2014
    6
    Thanks Received:
    Durham
    Country:
    Hello,
    Im looking for some advice on the damp patches on one of my walls. Last year I noticed patches with the salt which made lots of the paint flake. It bubbled and in the end to make it better I scraped it all back which was falling off. Then painted over with some damp proof paint, the skirting boards were wet and mouldy too.
    Added pictures - album - walls
    The damp on the walls was on a corner and also patchy on other walls. From the internal pic you can see it varies in height. It has come back and obviously the quick fix wasnt the best option. The patchy colours on the wall, its not all down to damp, there was a slight difference in colour due to the paint texture from when i repainted over the damp paint. It has got worse recently since rained so know its an issue.
    The wall behind has a few exposed bricks with no rendering on. At the bottom of the wall, there is 4-6inch 'gully' between the external wall and the footpath paving. When it rained the otherday, this gully got full of water, i brushed it out and wondered if the water is getting in through here and then rising into the brickwork.
    Also in certain parts of the rendering, there are cracks, from pics you can see well i think it must go up majority of the side of house.
    One of the bedrooms upstairs I can see what looks like damp patch on wallpaper high up, which is on this same side of the house too, probably from the same issue.
    Its difficult to know what potentially needs doing. If I just need all the rendering redone, if i had to do this side, id have to do the entire house. My previous house, I had rendered and there were none of these damp issues, cost me 5k :cb
    Any experts can offer any advice on the internal and external issues, if i need to consult damp specialists or if just require the house to be rendered again. Thankyou for any advice given. Would like to know what Im looking at before getting experts aka quotes
    Lee
  2. Guitar_man
    Guitar_man
    20 Nov 2010
    229
    Thanks Received:
    20
    Country:
    I would repair rerender point the corner first. Then ventilate heat the inner surface to see if it drys out.
    If there are any cracks from outs side running down to the wet patch inside, get them repaired.
    Cheers,
  3. Sponsored Links
  4. woodland81
    woodland81
    10 Aug 2014
    6
    Thanks Received:
    Durham
    Country:
    thankyou,
    the exposed brickwork on the corner, is the opposite side to where majority of the damp issues inside are occuring, could that still be the cause and that its travelling inside across, then up.
    Id only know of its done the trick, by removing the damaged plaster/paintwork inside, redoing and seeing it it reoccurs?
  5. Guitar_man
    Guitar_man
    20 Nov 2010
    229
    Thanks Received:
    20
    Country:
    No. The water will fall but not necessarily in a straight line. Check for water source, leaks, cracks points above.
  6. Sponsored Links
  7. ree
    ree
    6 Feb 2014
    3,193
    Thanks Received:
    447
    California
    Country:
    You really should read up on recent posts and pics on this very subject.
    Perhaps you will tell us if you have solid walls and floors, and maybe you will scan a plan view of the house showing where various concerns actually are - eg. interior damage in relation to exterior issues?
    What is your priority - the various damp and render issues or the patio door installations? AAMOI: its best practice to cut the brickwork, and lintel the doors, before rendering.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
