Damp Proof Injection.
8 Aug 2007
Warwickshire
I am currently sorting out a damp patch at home around the base of my chimney, I've read up on what I need to do to remedy it and I've sourced everything I need, including the damp proof cream to inject. I have done a bit of research on to how to apply the damp proofing and on every guide I have seen it shows it being injected into holes drilled directly into the mortar between the bricks and yet in every example I've seen in the real world it is injected into holes in the middle of the bricks themselves (I assume drilled down at an angle to meet the mortar).
So, which is the best way to do it?
Yes, don't do it :!:
Repair or renew flashing around the chimney, repoint the mortar etc, find out why it's damp, then deal with it
Not wishing to fall out with you Masona, and I agree that he shouldn't be considering injection at this stage, but don't you think that if the problem is at the base of the chimney, it is highly unlikely to due to the flashings.
He could simply check this out by looking inside the roof as this is were the moisture would show first.
I would be asking is it a solid floor, and has the chimney been sealed off and then go from there.
No problem, you're entitle to disagree, I generally believe that 99% damp problem can be dealt with without having to use injection treatments.
Could be but a photo will be clearer to see
