Damp Spots in Floor - Advice on how to replace
9 Oct 2014
Hampshire
Hi
I am new here and just wanted some advice please, on my (fairly) recently purchased property.
I have just had the guttering completely replaced but have now just noticed that the small extension on the back of our house is suffering from some of the plyboard/plywood under the lino flooring being damp in places. I presume this is moisture rising from beneath?
I want to replace this and judging by the time the extension has been up (10years +) and the fact the previous owners seem to have bodged every problem I have come across I wanted some advice. I am assuming there is either no DPM (allowing moisture to rise up) or it has given up the ghost. I will be removing a few boards at least, this weekend to inspect
Assuming the base of the floor is concrete....
Do I lay a DPM over the concrete base and then lay specialist flooring plyboard/wood on top of that. Will I not damage the DPM by screwing into it? Obviously the walls are already constructed so how would I fully lay the DPM?
Do I need added insulation in the above scenario and if so where would it go?
Is there a better way of doing this before I lay the final flooring (laminate) ?
I have read about screeding but am unsure what its purpose is. Can it serve as a DPM if done with certain materials?
Many thanks for any help?
Matt
Why not research recent similar posts on here, and then remove your board(s), and then come back with your findings and pics if possible?
