I have alot of condensatoin on the chimmey breast in the loft which i think has caused a large wet patch on the bedroom ceiling. I have an electric fire but there is a floo fitted.
Can anyone suggest a solution to this please.
Where you have the electric fire, have you sealed off the flue? If so get a vent installed.
More likely a wet chimney breast and a large damp patch on the ceiling are the result of a leak. This could be a flashing problem so this needs checking.
If you could upload some photos it should help identify the source of your problem.
