Danfoss TS715si stopped working HELP Please!
24 Jun 2012
Blackpool
Hi All, this happened yesterday, at least the weathers not too bad.
The danfoss unit is blank. There is 240v going to the unit, but no display, no red LED, the unit appears completely dead. I removed the unit front piece, checked the voltage on the backplate at the teminals where the pins locate and yep 240v there.
I suspect the unit has failed, it's about 4 yrs old.
The remote temp sensor is sending temp information to the receiver , just the programmer display is blank and like I said no indication at all that it's alive.
Your help would be very, very much appreciated.
Chances are you had a 13 amp fuse as protection and a fault developed. The timer then acted as a fuse instead of popping the 13 amp fuse. Happens often
Before you jack in a new programmer, check the electrics and fuse.
