Danfoss Wireless thermostat losing signal
The baxi stats plug in to the pcb on the boiler, dunno how the danfoss set up is. Does it plug in to pcb or wired in to roomstat connection?
What Baxi stat plugs into which Baxi PCB.
Danfoss RF does not plug into the PCB, it is wired to terminal with two black wires (if the boiler is a current generation Baxi appliance)
Read posts mate, I was giving an example of the wireless stats that I have fitted, it was a duotech, if you haven`t fitted any fine, the op`s was a danfoss. Most boilers now have a wireless stat option. :wink: and a lot just plug in to the board from the front where the old mechanical timer/clock used to be. It`s called progress. :wink:
Little plumb, afraid you have progressed too far ahead of the regulars here.
What (BAxi part number) radio wireless stat did you fit to your Duotec. How did you plug it onto the PCB (header has 4 wires that go to the clock- hence you cannot plug the said unit ONTO THE PCB but only connect to lucar connectors instead of the timer the boiler comes fitted with)
