Hi, I have a (1992) Vaillant Combi boiler VCW GB221H. Last month it failed (both hot water & heating). No apparent relay / pump action.
Recently I have found that if I vigorously turn / agitate the impeller (it's not particularly free-running - should it be?) on the pump before switching the heating on, I can eventually get the boiler to start, and it works as normal (heating & HW), but once the pump switches off, it won't restart. It takes me ages to get it going again. Once going, it runs without any apparent labouring.
I have resorted to setting the room thermostat to max (to ensure the pump is always on) and regulate the boiler temperature using the control dial on the boiler. I've had it running continuously (albeit, not very efficiently) for 2 weeks.
Any ideas? If the pump is knackered, surely it would never run
