Bought this second hand. Saw it work and took it home, it worked fine three times, then put it on the Intensive wash (v dirty dishes) and noticed water coming out of the under side - and the pre wash light started flashing read on internet to tip slightly and empty the base - did that and then checked the drain pump and cleaned it out. put it all back together and it worked - all be it for a little while then the dreaded water started leaking out underneath and then it blew my trip switch. noticed a black rubber pipe loose underneath by the water sensor should it be attached to anything? Ive cleaned out every bit of filter I can get to - have I forgot something?
Im at my wits end!
Help
Im at my wits end!
Help
