De scaling
7 Feb 2005
If lets say a heat exchanger was seperate from a boiler lets say a Thorn appollo 15/30 gas boiler and you were about to descale just the exchanger on its own,
what would you use?
how would you use it?
whats the exchanger made from?
kevplumb said:
lets say hydrocloric acid
lets say VERY CAREFULLY
copper
WHAAAATTTT????? You trying to induce chloride attacks on the stainless steel or summat?
If it's on the DHW side, citric acid will work fine. If its on the primary side, phosphoric acid will work. I did it with Kamco's FX2, no problems.
I wouldn't have thought Cl would do a lot in the time it's in there. ?
I can't use Kamco without a clear flow, can I?
The seals or compound on the joints to the exchanger are red and look very thin, obviously not PTFE, what product is this?
Would it be worth removing the exchanger on its own or try to de scale the whole system? it seems the exchanger is so scaled it kettles the water inside, causing awful noises yet the boiler burns well and pumps fine
copper
since when has an apollo had a sec h/e and when was it stainless :?:
scuse me if i missed something here
but lets say the heat exchanger was seperate from a boiler :lol: :lol: :lol:
but lets say the heat exchanger was separate from a boiler :lol: :lol: :lol:
Lets say as in lets imagine didn't mean its actually sitting in front of me right now, just trying to get some useful advice which is damn hard from some.
Asking a straight question without all the flowery bits might have got a straight answer.
I searched the forum before posting
I posted several threads detailing as much as possible
http://www.diynot.com/forums/viewtopic.php?t=20757&highlight=apollo
http://www.diynot.com/forums/viewtopic.php?t=20737&highlight=apollo
What else can I do :?:
How do I know? I know nothing about gas boilers, damn dangerous if you ask me.
