decking help - posts and joists
22 Apr 2017
hi guys, built a few decks before but need a little help with this one.
deck size is
2.4m across
3.0m in length
deck will be raised just off the ground. I will post a pic of the location in a second to give you a better understanding. this deck will also in the future have a hot tub on so will need to be sound for the extra weight.
c16 4x2 would be better but i feel 6x2 would be better in terms of tub support .
anyone be able to nock up a quick birds eye view of post and joist spans .
cheers
dan
this is the area that needs to be covered from the fence 2.4m across (middle of wall pillar)
then 3m from wall out. (basicaly area were 4x2 is crosing).
as you can see there is a little paving to the right but i will prob still put a few posts here.
dont really want to use 6x2 due to height but if thats what it requires then so be it .
wall at back is single brick so wasnt sure about attaching a ledger to this , probably a few posts just in front of footings then overshoot the rail to the wall by a few cm
for got to add in 4 corners there will be 4x4 posts for a pergola like structure over the top
