Decking Query
18 Nov 2009
Cumbria
Hi there,
I'm in the process of installing a raised deck area in my back yard, from what i have seen on the internet after you fit ledger timber to the perimeter you support the decking joists on metal hangers into the ledgers. Does anyone know what type of hanger to use? the deck joists are 150mmx47mm there are loads to choose from. Saw these in my local Wickes http://www.wickes.co.uk/Wickes-50mm-Speedy-Joist-Hanger-Standard-Leg/p/240385 and wondered if they would do if i cut the legs down to 150mm, to me they just dont seem very thick at 0.9mm thick galv but they may well be fine. Any advise if these are ok or where and to buy if something is more suitable would be great.
if you want heavier ones, you need to go to a builders yard, like travis perkins
but you can also but join them and screw them
I have a different question. When screwing the frame into a brick wall, what fixings should you use, I was thinking 10x100mm frame fixings
Any purpose made joist hangar will be fine. Despite looking flimsy the load they can take are massive.
You can simply butt join them and screw with timberlok screws or similar. Of course only If you can get at the back face of the ledger to put the screws in. If its against the wall then hangars are fine.
