Decking
3 Aug 2009
Somerset
Hi
I’ve contacted a builder in to fit a 3x4m deck area for my hot tub. He’s making progress but he said he ran out of brackets for one of the panels (the one next to the render) so stuck it down. Tonight I stood on it with a bit of pressure and it seems to be moving.
Presumably it can be pulled up and he can/should fit brackets?
Cheers
Depends on the sealant used, the hybrid polymers like CT1 stick fast, but if it’s moving already it might be possible to get a flat scraper blade underneath. Worst case scenario you mash it up and replace it.
I went into B&Q once and as I walked in, one of the store assistants asked if I wanted decking. Luckily, I got the first punch in………
The stuff he was using that he said was very good, in fact want sticking at all. Pulled that stuff off and used a couple of brackets.
Luckily this but it’s the side so Sony be used much
All seems to be holding up well
