Over the past 6 months my bathroom wall (the external one) has started to flake. I believe it is finished in either vinyl silk or bathroom paint. The plaster underneath it looks fine, the flaking is obviously caused by condensation on the walls. I am therefore intending to have an extractor fan fitted soon, although would say the bathroom is adequately ventilated via the window at present.
Having read the various posts on the topic, I am minded to avoid bathroom paint but instead use a high quality vinyl silk emulsion, or a water based eggshell.
Intended methodology is:
1. Rub all walls down with fine sandpaper
2. Clean thoroughly with sugar soap
3. Apply chosen paint directly onto walls (one or two coats)
Any comments on:
- choice of finish
- can new paint be applied directly onto existing finish assuming it has been sanded down to give a key
- Should I apply a mist coat or primer?
- How long should I leave everything before it is safe to use the shower and bath again? 24 hours?
Alex
Any comments on:
- choice of finish
Alex
