Decorating Below Zero
bsr
5 Aug 2008
Gloucestershire
Hi Guys
I'd like to decorate my porch; can I use the following below 0 without issues?
Solvent-based gripfill
Acrylic Caulk
Emulsion
The materials are stored in the house so are currently at room temperature, but will obviously get cold pretty quickly in an unheated porch!
I would not do it to be honest, can you not plug in a little convector heater to warm the area up.
Not advisable as the paint, filler etc will freeze as it takes so long to dry. Unless you can increase the temperature to the minimum the product specifies your asking for trouble.
Thanks guys, the reason I'm asking is because there isn't a minimum temperature specified on the tubes / tin.
As you say, I'm tempted to try and use an electric or gas heater to keep the temp. up.
