Decorative Wall Painting Techniques
11 Jul 2011
Washington
Do your walls seem dull and uninviting? Do you long for a cozy, welcoming room? Consider decorative wall painting techniques, such as sponging, ragging, stenciling or stamping. Even if you have no experience, you can brighten even the dullest room quickly and cheaply with one of these easy decorative wall painting techniques.
Before painting your room, pick out a color scheme for your walls. When you chose your paint, remember that many painting techniques use two shades of one color. If you are using one of the techniques that does use two shades of color, you can pick a darker color than you normally would chose for your base color, since the lighter top color will make the final result much lighter.
To sponge or rag a wall, paint on your base color and let it dry thoroughly. Then, dip your sponge or rag into the lighter paint color and sponge or drag the lighter color over the base coat until you are satisfied with the effect. If you are unhappy with your final result, you can repaint any areas that you don't like with the base coat. Once the repainted area is dry, repeat the faux painting technique.
As a matter of fact there is in certain quarters still a demand for such finishes as rag rolling and faux.
Dec
