Degloss coving
3 Sep 2015
Hey everyone,
The, coving in my hallway and landing is a nasty shiny cream gloss. If I want this to be a matt white how should I go about deglossing it so the matt has something to adhere to?
I'm pretty sure it's polystyrene coving in most places and one plaster coving so I need to deal with both.
I considered a light sand, as you'd do on wood, but thought that could be a disaster. I have polycell liquid sandpaper, still unopened, but thought the chemicals may melt it!
Advice much appreciated, thanks!
You could use something like the Owatrol ESP
http://www.owatroldirect.co.uk/product/esp-easy-surface-prep/
You wipe on, wipe off.
Let it dry, then paint over it.
Mind you, oil based undercoat or waterbased primer will probably suffice (and be cheaper). They might be less chip resistant, but how often do you bash coving? Matt emulsion would probably be ok. I have only seen it crack when humidity levels have been very high (eg bathrooms)
I'd hope bashing coving would be very rare - perhaps carelessly moving a ladder but I struggle to think of other examples.
Could you give an example of a half decent water based primer I could get from say B&Q or something? - I'm thinking I'd put Dulux Trade Supermatt over this (and the new plaster once mist coated).
It doesn't need to be particularly good acrylic primer. I use the Leyland stuff because it is easy to sand. Toolstation sell it
Get some med grad wire wool, roll into golf balls. Each roll will key 2m or so, rotate ball every 200mm section or so.
A decent trade emulsion will happily stick, no prime needed.
Thanks for that tip, I'm guessing that like keying gloss with sand paper you'll feel a (probably subtle) texture change to know you've rubbed it enough with the wool?
