Ah, ha !! Not so del(l)icious after all !!
Given the demise of AdamW's Power Supply, just thought I would run a quick availability check for the Dell XPS---- oooer ! Proprietry ATX board, connections from PS to Mo-bo not standard, twin plug / sockets, even worse the 'standard' PS single plug would fit on the 20 pin socket, apparently frying stuff upon switch-on !!
Found this :-
Dell Power Supply Adapter (Dell to ATX Power Supply Converter)
The above shot shows the problem sockets in the lower pix.
Upper right shows the cable required to convert an ATX stnd PS to suite Dell Mo-Bo.
Upper left, that cable fitted to Dell proprietry Mo-Bo.
Only able to Google one supplier of 'quiet' compatible PSU -- The R-R of PS suppliers ? http://www.pcpowercooling.com/home.htm This offers an upgrade to the dell spec PSU .. with correct wiring.
Do, Pc Power and cooling Inc, have a UK supplier ?
Does anyone in UK make Dell proprietry, compatible, upgrade (or stnd) Power Supplies ?
When time comes for new PC, I shall enquire from Dell if they can / will supply a machine which complies to current standards and therefore becomes upgradable without being tied to Dell parts ...
Could be the end of a good relationship !!
P
Found this :-
P
