Depth & Position of Brown Waste Pipe?
Status
Not open for further replies.
8 Jul 2008
Derbyshire
Hello, I just wanted some guidence. Neighbour has built a side return extention which is set back slightly from the boundary (so a 6-8 inch gap to the boundary). The properties are on slightly different levels. They have a toilet waste pipe that comes out from the front elevation and joins the main brown waste pipe under the ground. Howver they have a "dead end" section that slightly returns around the side of the extention (along the border).
1. Why is this dead end section needed?
2. Because of the level differance, it is very near the surface, maybe less than 10cm below? It seems to be in quite a vulnerable position. Should there be a minimum depth?
Status
