desperate baxi solo 3
25 Nov 2005
Liverpool
Please anyone out there with any help changed pcb board just getting ignition clicking as though no gas, worked for 3mins then just clicking again could it be solenoid thanks.
Why have you changed the pcb?
Was it doing the same before you changed the board?
Have you checked the pilot injector?
changed board as relays had burnt out,this has only happend since new board gone in, boiler ignited for about 5mins then went out then just started to click no overheating light on just no ignition.
I will invest in pilot injector, could you tell me why this has happened after replacing new pcb board,also solenoid sticking was another suggestion is this possible, thanks.
