I've just received by second DWS780 and it seems to have a similar/same fault as the first - the electronic brake doesn't work. (the first one also had other issues)
If I run the machine to full speed and then release the trigger it takes around 3.5 - 4.5 seconds to stop - is that normal?
I have a Makita MLS100 too and the brake on that stops within a second - you can really tell that the Makita is braking.
I can't seem to find any reference to how long it should take; a few people seem to suggest the DWS780 should also be 'within a second'.
To me it seems as though there isn't any brake, just friction slowing it down.
Anyone have one of these and can provide any help?
Thanks,
TS
UPDATED!!
Just spoke to helpful guy from Dewalt technical support. It seems the older versions (708 etc) used an electronic break, but the newer ones (like the 780) don't - they just use the friction of the belt to slow it down and this can take "up to 10 seconds". Seems they changed to this way of working because the motors were failing due to lots of quick stop/starts since the old way of braking was to put the motor in to reverse for a brief while to stop the blade. And this resulted in the motors burning out.
Thanks,
TS
UPDATED!!
