DHW connections to vented cylinder
26 Oct 2009
Cambridgeshire
Hi there,
I'm renewing the connection to my vented cylinder, and have a question about the piping layout to maximise flow to my taps. I understand the need for a 450 horizontal offset, and then a T-connection with vent going up and hot going to taps. This will be in 22mm pipe.
My question is: How best to orient the T-connection piece?
Most installs I have seen have the T-connection with the middle leg connected to cylinder and the ends connected to vent and hot taps.
It seems to me that if I connect one end of the T connector to the offset pipe from the cylinder, the other end heading horizontally to the taps, and the middle bit of the T going up to the vent, I will maximise the flow to the taps (no sudden right angle bend needed through the T piece).
Will this work? Seems OK in theory, but not sure about practice (voodoo of parasitic losses and air bubbles etc)
shouldn't see any problems with that if your supply to your taps go's off
horizontally.
