Hi guys
I have a quick question regarding the correct pre-charge pressure for an expansion vessel (24 ltr) on the cold supply of a DHW cylinder (300 ltr).
As measured after a combined 3 bar PRV + 6 bar safety relief valve assembly, the static pressure of the cold supply is 2.5 bar. The dynamic pressure is 1.7 bar with a few cold taps open.
What pressure should the expansion vessel be charged to when it is disconnected from the cylinder?
Rest assured, I have no intentions of recharging the vessel myself as I am not qualified to work on unvented cylinders, but it seems every plumber I ask has a different answer. Some say charge it to the PRV limiting pressure, others say charge it to the dynamic (working) pressure of the cold feed.
So, can some kind (competent) chap on here provide me with the genuine answer?
Thank you in advance
Bob
Bob
