Hi fellow people, Help needed please
I have a Vaillent EcoTec Plus 831 which when hot water is turned on, the boiler starts firing up and immediately glitches or resets or reboots very quick and cuts off heating up the water.. and leaving the water on, the boiler retrys and does the same thing 2\3 times before burner stays constanly on and you get hot water.
theres no low pressure issue and seems to be fine.
there are No Error codes displayed. Reset to factory and still same.
this happens from cold start mostly i noticed when the boiler cools down.
Things that are new and recently changed in this boiler and less the 12months old are heat exchanger\divertor valve\ntc sensor\flow sensor\vesssel\gas valve
the only thing i can think of is the PCB?
posted a video:
as you can see start of the video i put the hot water tap on, nothing happens and temp starts to drop, when it reaches 32\31c you can hear it trying to fire up... when it does fire up full throttle, it cuts off, ... then starts to fire up again and this time round it stays on...
sometimes, when it cuts out, it kinda reboots it self, like scren goes off split sec and continues to try to fire up...
any ideas?
many thanks
Neil
posted a video:
any ideas?
many thanks
Neil
