I have a 56 year old solid fuel Aga used for cooking and space heating. It seems a waste not to utilise the aga's hot water capabilities so I've a acquired a glass lined boiler which I intend to fit.
The aga will be connected up to a vented single feed indirect hot water cylinder (Gledhill primatic) which I've also just acquired.
The Aga system will replace the current DHW system of an immersion heater and a direct cyclinder.
A couple of questions:
1. Does the Aga still require it's own f&e tank or will the primatic serve that purpose?
2. Does the Aga flow primary require it's own vent pipe when linked to the primatic?
