DHW problem a question
13 Dec 2008
It has been suggested that my combi problem, inability to run a hot bath other than at a very slow rate is most likely to the hardness of the local water. Recommended attempt as cure is to fit an Aquadial Combicare scale reducer and a new thermistor. From that i presume that the water affects the thermistor, but am curious to know if an iffy thermistor would influence the DHW in the way now suffered and how else.
Please excuse my questions if they are numpty, but being a fool can be educational.
What size is the combi in kW?
What is the actual flowrate in litre per minute?
What is the cold mains temperature?
What is the tap temperature?
