feed back on completion of diaphram, some great tips of everybody who replied, especially the 90 degree screwdriver, worked a treat. Still had to remove filling loop and water to water heat exchanger, but once they were removed it was straight forward. its a pity i did,nt listen to all the advice about the isolation valves on flow and return, turned off the flow and guess what, you guessed started leaking so i left the others. Drained the system a little, but then when i come to removing the filling loop i got a nice surprise, an early cold shower because worrying about turning the rest of the isolation valves of i stupidly left this open, managed to turn it of after riding in on the waves! when i filled system back up it kept sparking up then going back off, after about 15 mins it stayed on, working ok now, i take it it was because it was full of air. Any feed back would be great.
