Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
TN-S may have a visible seperate conductor entering the building for an earth, or the sheath of a lead cable may be used to supply the earth. You may also find that a SPLIT CONCENTRIC cable has been used to feed your property, and the earth connection is on the side of the service head. BUT this looks identical to a PME or TN-C-S system, and you cant tell with out removing the service head cover which it is. (you must not do that).
It is possible to do a loop impedance test from L to N and L to E to determine.
PME or TN-C-S have the earth connected to the neutral inside the service head, and you cant normally see this link.
