I have recently moved into a house where none of the central heating pipes have been insulated.
Today I lifted one of the floor boards on the ground floor. The 22mm pipes underneath runs tight against the floor board so without chiselling more out of the joists there is no room to put any foam pipe insulation. There is not even enough room to put felt.
Is there anybody who can suggest an alternative insulation that I can use? I realise I will probably still be heating the floor but at least I no longer be heating the ground.
Any help will be much appreciated.
