    Dismiss Notice
Digital Voltmeter at Lidl £9.99
Discussion in 'Electrics UK' started by KennyPowers, 20 Jan 2019.
  1. KennyPowers
    KennyPowers
    1 Jun 2017
    151
    Thanks Received:
    2
    Country:
    Hi all,
    For info they got a Powerfix Profi Digital Multimeter for sale at Lidl at the moment.
    Obviously no Fluke, but seems to be better quality than the usual ones for £10 and under. (Ok for the home DIY etc). Supposedly safety approved as well (unlike the Chinese ebay ones...)
    I picked one up, will take to work to do some tests on it, see how if fares.
    https://www.lidl.co.uk/en/MiddleofLidl.htm?articleId=19556
  2. Sponsored Links
  3. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    What does this say? I can't make it out...
  4. KennyPowers
    KennyPowers
    1 Jun 2017
    151
    Thanks Received:
    2
    Country:
    It says Cat III 300V.
    There are some video reviews on YouTube:
  5. 333rocky333
    333rocky333
    12 Jan 2008
    8,427
    Thanks Received:
    902
    Essex
    Country:
    similar ones on ebay look like it may say max 300v catIII
  6. Keithmac
    Keithmac
    10 Oct 2017
    2,148
    Thanks Received:
    342
    Country:
    Looks similar to the cheapy I bought from screwfix to keep in the caravan.
    Notice that has a continuity buzzer, very handy and mine doesn't!.
  7. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
  8. ericmark
    ericmark
    27 Jan 2008
    18,631
    Thanks Received:
    1,746
    Llanfair Caereinion, Nr Welshpool
    Country:
    That's less than I pay for a set of GS38 meter leads. If they are GS38 must be very small fuse! If not than meter may be OK for mains, but leads are not!
  9. securespark
    securespark
    11 Jan 2004
    37,154
    Thanks Received:
    1,290
    Country:
    No, they put them on sale deliberately.
    • Like Like x 2
  10. Sponsored Links
  11. mattylad
    mattylad
    27 Apr 2008
    8,303
    Thanks Received:
    633
    Country:
    I almost bought one today, while I was in there getting a replacement PBSA12CB battery screwdriver. (I have been waiting all (for a) year for this to return!).
    I still have its predecessor though, sadly the buzzer on it is a tad poop.
  12. SUNRAY
    SUNRAY
    28 Jul 2009
    5,604
    Thanks Received:
    430
    Kent
    Country:
    I took the second one back today, with both of them the resistance of the 2 test leads held firmly together was wandering all over the place and never below 20Ω.
  13. plugwash
    plugwash
    28 Mar 2004
    9,595
    Thanks Received:
    378
    Country:
    Which afaict (assuming it actually passes the requirements) is fine for most things a DIYer would do, but probablly falls short for a proffessional electrician, who would probablly want CAT IV (to cover work on outdoor parts of installations) 600V (to cover 3-phase work).
  14. plugwash
    plugwash
    28 Mar 2004
    9,595
    Thanks Received:
    378
    Country:
    http://www.hse.gov.uk/pUbns/priced/gs38.pdf says
    Using both fused leads and a multimeter with internal protection ( EN 61010, which the TUV test certficate says this meter has been tested agaist ) seems like a sensible "belt and braces" approach, but does not seem to be strictly required.
  15. JohnW2
    JohnW2
    28 Jan 2011
    48,659
    Thanks Received:
    3,191
    Buckinghamshire
    Country:
    I personally agree (and would happily use it on 230V single-phase) - but I suspect that some would argue that a 300V rating is not adequate for that, because of the possibility of spikes/transients >300V.
    Kind Regards, John
  16. plugwash
    plugwash
    28 Mar 2004
    9,595
    Thanks Received:
    378
    Country:
    My understanding (from secondary sources, I haven't read the original EN/IEC standard) is that the way the system works is that the voltage refers to the normal working voltage of the system and the category refers to the type of circuit. Based on the nominal voltage and category the standards specify what level of overvoltage transients the meter must be tested to, presumablly based on what the IEC thinks is likely to be encountered in such systems.
  17. JohnW2
    JohnW2
    28 Jan 2011
    48,659
    Thanks Received:
    3,191
    Buckinghamshire
    Country:
    If that is true, then I would obviously be even happier to use it for single-phase 230V - but, as I said, I would personally be happy to use it for that purpose even if 300V was the maximum actual voltage it was required/guaranteed to be able to tolerate.
    It does seem that 300V is rather unusual - most Cat III labelling I've seen seems to be 600V or 1000V.
    Kind Regards, John
Loading...
Share This Page
