Hello there
I've been reading this forum for years throughout our renovation project, but this is my first ever post. Thank you for all the helpful advice received on here over the years.
I have finally come undone on something which I can't resolve and feel hugely frustrated by!
We are renovating a 1930's semi, and I am replacing a standard light switch with a dimmer switch.
The light switch is a Marbo 250W one way dimmer switch (B&Q), and the light is a 5 lamp DAR Vaudeville chandelier (each lamp having a 40W bulb).
When i wire up the dimmer switch, and first turn on, the switch works, and the dimmer operates smoothly and correctly. However, once the switch is turned off for the first time, when i turn it back on, i have either intermittent flickering, just the odd flicker, or no light at all. This worsens rapidly until the switch just doesn't work and the light remains constantly unlit.
I have repeated this by taking the switch off and putting back, again it works in first instance, and starts to fail after being switched off for the first time.
I have now also tried this with a Marbo 400W one way dimmer switch (after reading posts on here) and the problem is the same as above.
I'm completely baffled. In my mind:
1. It can't be the light, because i know this lights up when initially connected.
2. It can't be the connections in the back of the switch, because i have made sure these are secure when initially connected (and the light works when initially connected).
3. Something must happen when the dimmer switch is turned off for the firt time, that then stops the electricity passing through the switch when turned back on.
Any advice greatly received. I'm not sure my family will enjoy eating their turkey in the dark this Christmas!
Ross
Ross
